more flickering lights
18 Jan 2006
Sussex
Last night the surface mounted spots and the LED lights in the room next door flicker, buzzed and then died. No other lights were effected and the fuse (RCD?) didn't trip. Trying them periodically they would occaisionally buzz, flicker and even come on briefly. There is no apparent damage/water leaks in the roof space. the light fitting in one room was changed a month ago. Where should I start looking for the fault?
But not a double post caused by someone getting a spurious error message, hitting the back button and clicking "submit" a second time...
In 'confusing lights problem' fozwold said:
Last night the surface mounted spots in my bathroom and the LED lights in the room next door flickered, buzzed and then died. No other lights were effected and the fuse (RCD?) didn't trip. Trying them periodically they would occaisionally buzz, flicker and even come on briefly. until they finally died. There is no apparent damage/water leaks in the roof space. the light fitting in one room was changed a month ago. Where should I start looking for the fault?
So a 20 minute gap, a different topic title and different text.
Fozwold - why did you do that?
Sorry.
I found a different section on the site that seemed to have a lot more posts about lighting and I thought the 2nd post was going to added to that list.
Ah - the old "topic originating from a How To page" problem - sorry I didn't spot that... :oops:
