More on sub-mains
28 Jan 2011
Buckinghamshire
Following recent discussions, I have continued my exploration of my electrical installation, which has resulted in a further question. The short-form of the question is as follows; depending on replies, I can provide further background/detail if required.....
Is it acceptable to have a single switch-fuse protecting two sub-mains (wired separately from the switch-fuse) given (a) that the fuse would be satisfactory for either of the sub-mains alone and (b) that the rating of the fuse is satisfactory in relation to the total design current of all circuits involved? On the face of it, I can see no real problem with this (even in the vanishingly improbable scenario of simultaneous shorts at the end of both sub-mains), and can so far find nothing in the regs which appear to prohibit it - although, as always, I may be missing something! The context is such that lack of discrimination/selectivity between the two sub-mains circuits would not really be an 'inconvenence'.
Kind Regards, John
you would be installing larger than necessary, discrimiation and isolation are the issues
prefectly ok but not good engineering
Thanks. This is not a proposed installation, but an existing situation which I have inherited. As I said, lack of discrimination (and, similarly, lack of ability to isolate the sub-mains separately) is really not much of a concern. My inclination is therefore to allow it to remain as it is.
Kind Regards, John.
