Mosaic tiles: Difficulty, cost...
15 Nov 2005
London
Morning all,
Some questions regarding mosaic tiling for beginners which I haven't been able to find elsewhere:
Are the mosaic tiles harder to put up than normal tiles? I was informed they move round a bit more, I thought they may be easier given the ease of cutting....
Does each sheet of mosaic tiles need seperators?
and what sort of cost should I expect if I got somebody in to do it, based upon: 8 sq m of wall, London based, mosaic tiles, inc. behind a toilet and sink? I read £35/sq.m. on a different website.
Let me save you some time.... if you're planning on fitting mosaics around a shower, I'd advise you to forget it. You'll end up with grubby grout in next to no time. If not tiling around a shower, then you can get non-slip adhesive specially designed for mosaics.
OK, so got a quote...
Bearing in mind, the area to be tiled is actually 4.5m.sq. in a downstairs toilet. New walls. Mosaic tiles, excl materials.
The tiler estimated it at 3 days work, ~ £420. :shock:
Is this a reasonable quote?
Thinking of flogging the newborn to cover it...
get a couple of other quotes first. should only take 1-2 days max for a job like that.
