Old style Fuseboards always seem to be mounted on Wood. Is this a prefered method or just old way of doing it? Is new CU installed directly onto plastered wall ok?
One advantage in using a plywood board on spacers, is that you can drill holes in the ply, and run the cables really neatly into the back of the consumers unit enclosures, as modern ones tend to have open slots at the back to do this with.
