Mounting TV and cabinets to brick wall
14 Nov 2006
Manchester
Just after a little confirmation I'm choosing the right screws for the last DIY job before Christmas. (And also stop over thinking it as I went deeper down the Google rabbit hole!)
Looking to hang a full motion perlegear bracket to a brick internal wall, TV is 75" weighs 30kg, went off the usual advice here and looking at fischer fixings would the pack of 10x50 with 7x69 bolts be more than overkill for that? (looking to pick up from tradefix not sure if the link would be frowned on).
As for the cupboards they are IKEA besta with the rails and was thinking 8x40 and 5x60 screws again in a Fischer pack.
Thanks!
You can do it a few ways.
8mm masonry holes
Fischer duo power long plugs
Coach screws
If you hit hollow bricks or joints when drilling holes.
Get some 6mm threaded bar. Called Threaded Rods M6
Chemical fixing. Any. Don't matter which as long as it fits in a standard mastic gun.
Inject holes and push bar in.
When set which is a couple of hours add nut and washer
