Hi All,
I want to mount a new TV on my front room wall, but need some expert advice.
There are studs in the walls but they are metal, not wood.
I mounted a similar but smaller TV (12kg) on the wall in my bedroom using plasterboard anchors and it seems to work fine. The plasterboard in my flat is quite thick, about 15mm probably for sound proofing.
Anyway - my question is - could a larger TV (15kg) be mounted using the same method on the front room wall, or is it likely to fall off?
What do people think?
Many thanks
Many thanks
