I've bought a TV wall bracket and when I opened the instructions I found it says it should only be mounted by a professional. It indicates that a "3/16 drill bit, 1/2" masonry bit" is needed. I'm a complete DIY novice with no skills and all I have is a general purpose, £40 drill with a hammer option. It's good enough for drilling into masonry to, say, hang a picture, but I'm not sure if it's adequate for this task. Also, I don't have the required bit, just the normal sized masonry one you'd use for everyday pictures, brackets, etc. I'm not sure what size it is but it's only a fraction of the size of the lag bolts that come with the bracket.
I was wondering should I get a handyman with a proper masonry drill to do this for me, or go and buy the aforementioned bit and try using my own drill to do it ? It's not a stud wall so as far as I'm aware it's brick, though it could also be cinder block as I don't know what that is. The bracket can only be mounted on masonry. If you're interested, the TV bracket is a Levv WB2337TB and I'm mounting a new 32" TV on it. Any advice from someone who knows about this stuff would be greatly appreciated.
