Moved to new house - confused by central heating controls
4 Jun 2008
West Lothian
hi all
Thanks in advance.
I recently moved to a new house. It's 2 years old.
Downstairs there is underfloor heating and 5 Heatmiser slimline thermostats in each area.
Upstairs are radiators with trv's
Also upstairs is one Honeywell T4 thermostat.
I have programmed all the downstairs thermostats, all is good there.
Problem is upstairs with the Honeywell T4.
The instructions say that to adjust the schedule, I should press the 3 horizontal lines, then press + or - until I get to edit.
I can't get to edit.
The only options here are OP AF or BEWE.
None of these are explained in the manual
Can anyone help ?
I can't access whatever existing schedule is there for the upstairs area.
Appreciate any advice
Regards
If it’s battery operated, I’d check those 1st.
Have you tried doing a factory reset? Press and hold the menu and + buttons for 3 seconds then go to option 16 FS and change the parameter from 0 to 1.
Attached is the full list of options.
  • t4-ig-en1h32318056-001uk07.pdf
THAnks.
as helpful as that is, it unfortunately doesn’t help with my specific issue.
I still can’t edit the schedule and I don’t know what OP, AF or BEWE mean in the schedule menus ?
Any other advice/information ?
Thanks.
It was a very explanatory video, but didn’t help with my particular issue.
It’s totally frustrating.
I just want to re-set the schedule. It should be easy.
I know I should re-set the unit, but I am a bit reluctant to do that without some understanding of why the current setup is behaving as it is.
To do that I would like to know the meaning of OP AF & BEWE
Weirdly, the clock symbol is present, indicating that the unit is in temporary override.
Ok
I have cracked the conundrum.
BEWE = EDIT
The programmer must be configured in a language different to English !!!
Of course a reset would have rectified this, but at least I now know !
I have checked google translate and have no idea wheat language is set up !,
Thanks for all the help anyway
  • Thanks
Reactions: CBW
