- Joined
- 21 Jul 2004
- Messages
- 43
- Reaction score
- 0
- Country
Looking for some advice on the following procedure.
I want to remove a light switch (2way) from the middle of the hall (bungalow) to the end of the hall outside the bathroom. Now at the moment the switch is one of those horrible ones with a box and the cable running up the outside of the wall covered with trunking. There was another box switch at the other end of the hall but I have sunk that into the plasterboard using a back box and connected the cable in the wall.
Now my problem is that although it is easy to extend the switch cable to the other end of the hall and sink in the backbox I am concerned the electrical feed cable will be sharing a void with 2 copper pipes that feed the shower. I have a shower fitted in the bathroom that feeds directly off the combi boiler and has two water feeds running in the void of the wall behind the tiles.
So to put a picture in your head. I have a wall that partitions the end of the hall and the bathroom. At the moment there is nothing on the hall side of the wall apart from a door leading into the bathroom. On the bathroom side there is a shower valve that is fed from two copper pipes sunk into the wall and going up into the loft. I want to fit the switch on the hall side wall at the edge of the door leading into the bathroom. It'll look nicer and not be in a stupid position in the middle of the hall.
Is there a distance the cable must be away from the water pipes or can you never share a void in such circumstances? If not can anyone recommend a different approach allowing me to fit a switch in this position but not looking as crude as before?
Many Thanks in advance.
Russell.
Russell.
