- Joined
- 25 Jan 2004
- Messages
- 53
- Reaction score
- 0
- Country
The latches on several of our doors do not click in when the door closes, and some others require a bit of force to latch shut properly. So my thinking is that I must move the receiving part of the latches (on the door frame) a small distance so that the door part of the latch will click in without too much effort / travel.
Problem is that the distance to be moved will be quite small, so that the new screw hole will overlap with the old screw hole.
What is the best way to deal with this? Are there wood fillers out there that are strong enough to hold a screw tight? In the past when a screw hole has ended up being too big for the screw, I've just filled the hole a little with some bit of wood splinter (or a wooden match), but this seems to be quite heath robinson.
Cheers,
Mike
Cheers,
Mike
