Theoretically yes, but it'll make it a real pain in the ass to work on and you might not be able to fit it in whilst maintaining the manufacturers recommended clearances
hi I have the Potterton Suprima, just checked, can this be moved down into the kitchen base unit (under the worktop) with the flute going outside at floor level?
yes but as said before you'll need to follow the manufacturers instructions as the base unit will probably need vents and the flue will need adequate clearance outside
also, if I move the boiler down to base cabinet level, the flue will go directly outside at about 400mm from pavement level - would this be ok with a flue cover?
