Moving Citadel XRI control panel
25 Nov 2013
West Midlands
Good evening
I have some a couple of pipes and cables running down the corner of my kitchen, which I would like to box in.
This means moving the Citadel XRI control panel and a fuse (?) located next to it.
Am I right in thinking the following would work and be safe?
- Disconnect front panel.
- Disable tamper alarm.
- Turn off mains power.
- Relocate control panel and fuse.
- Turn power back on.
Is there anything else I should watch out for? I do not intend to disconnect and wires relating to this.
Cheers
shaun
Sounds good as long as the battery is in good condition , replace if it's not been changed in the last 5 years , if you can leave battery still connected you should be ok, worst case is external bell will kick in ( if installed correct and battery in bell box ok ) if totally powered down, mains and battery.
