In due course we plan to cancel one of our two phone lines. We wish to move the extensions to the line which will be maintained. The second line is provided by BT via a secondary pair in the drop wire, with a "split" in a weatherproof enclosure outside the property. From this 2 wires go to each master socket for the 2 lines.
I currently plan to run a new cable from the existing final slave socket (on the line to be maintained) to a new slave socket by the second master socket (for line which will be cancelled). I will then swap the extension wiring from this master to the new slave. This will require the running of a cable from one bedroom to another, across the hallway - certainly doable, but quite a bit of faff.
Is there an easier way??? Is the other line likely to be available at this second master socket? Even so, I guess it is probably better to run a cable to complete the circuit because this could be seen as tampering, even if the line is not activated, and will not be very expensive.
Finally, I presume that 2 pair cable is more than adequate for this join because only three cores are required.
Thanks.
Thanks.
