Moving gas meter to new porch wall
24 Jan 2018
Hi hoping someone can help. We are planning to build a porch, however the gas and electric meter is next to the front door, which means if we built the porch they would be inside of it, and also the gas service pipe will be built over, which I understand is not allowed.
I’m wondering how I go about getting these moved as the wall we would like them to go on (the front of the porch) doesn’t yet exist as it isn’t built, and I don’t know how to build this wall without temporarily building over the services?
24 Jan 2018
I should also add that the metres don’t need to move to the left or right, just forward a meter or so if that makes sense, so guessing this will be easier for service suppliers to connect
2 Feb 2006
Staffordshire
When you dig the porch foundations, locate the gas service (yellow plastic), photograph it and make a note of its location relative to the new porch wall. We usually use a squirt of spray paint on the ground or on the new wall below DPC.
You will then buy and build in a new gas meter box directly above the location of the service.
In the meantime, make an appointment with your gas provider to come and move the meter. Also have a plumber come round to decide on the domestic route for the gas back onto the exiting supply from the new meter location.
On the day of the meter move, have your plumber booked in ready to do the domestic bit.
Piece of cake job.
26 Aug 2016
Just to add a tiny bit of info to nose alls excellent post - if the internal gas pipe ends up longer or with more bends, you may need a bigger pipe on some of the existing sections. This is because the gas pressure drop allowed by the gas safety regs is very small (1mb)
21 Jan 2007
Devon
Hi hoping someone can help. We are planning to build a porch, however the gas and electric meter is next to the front door, which means if we built the porch they would be inside of it, and also the gas service pipe will be built over, which I understand is not allowed.?
Yet plenty of people do, I've even done plenty of projects under the eye of Building Control where the inspectors have been non perturbed by it.
24 Jan 2018
Thanks for all the info. So when I build the foundations should I bridge over the gas service so it is still kind of free to move?
As for the new meter box, is it okay to use a recessed box if i was to do timber framed porch? Or will it have to be a surface mounted one in this case?
And anyone know if this is all the same for electric meter?
Cheers
3 Nov 2006
Bedfordshire
this may be an option for the gas meter.
semi-con-gas-jpg.99924
2 Feb 2006
Staffordshire
No need. Just concrete on top or around it. If you decide to back-fill, to make bricklaying easier, back fill with sand.
The guys will dig down and connect a new piece of pipe onto the existing, bring it up the hockey stick and into your new box. They may salvage the old hockey stick and should deffo re-locate the old meter.
The one thing you could do is screw the stubby conduit onto the back of the meter box (before bricking in) and build around this when setting out your internal block-work. Otherwise just let your plumber drill it through afterwards.
Just make sure all the bits that are supposed to be in the meter box are there when you buy it.
14 Sep 2010
Rochdale
You can buy the built in boxes for about £25, don't screw them in though, the gas people will refuse it.
