moving kitchen
  • Thread starter Thread starter ACS
  • Start date Start date
ACS
7 Jan 2007
London
I am wanting to move my kitchen. The new location will be an interior wall and I will need to move the waste pipe. How far can a waste pipe travel under the floorboards. The new location will be approx 17ft away from an exterior wall or about the same distance to the bathroom. Any advice would be gratefully appreciated.
Thanks for info. So as long as I can achieve the correct drop it should be ok. Cheers.
40mm waste pipe can be run up to 3 m.
Fall of 7 1/2 degrees or 135 mm/m. run.
Keep bends to a minimum.
Do not fit bottle trap.
so would a drop of 10mm every m be sufficient using a 110mm pipe over a distance greater than 3 metres
I think Kev was just having a laugh!!! :lol:
110 mm. is the size of a soil stack :wink:
20 mm./m. run is ok for everyother thing but kitchen sinks. Kitchen sinks require a greater fall.
Kev was definitely having a laugh :lol:
40mm Waste Pipe is what you need. Make sure you clip it securely though, its a long run.
