Moving Toilet
16 Sep 2005
Buckinghamshire
Hi, I want to move my toilet 90 degrees so it is out of the way next to a chimney brest, the problem i have is the soil stack location, here is a photo of the toilet as it is now
http://i173.photobucket.com/albums/w79/lloydsno1/PIC_0006.jpg
ideally i would like to put it in the corner near where that piece of wood is glued to the wall and buy a corner toilet but i don't think that is possible unless they sell a corner toilet with side waste outlet, if not i would like to put it on the side wall where it is painted white at the bottom, that wall by the way is my neighbours house so can't go out through there
here is a photo of my soil stack
http://i173.photobucket.com/albums/w79/lloydsno1/PIC_0007.jpg
what is my best option for moving the toilet, should i run the waste inside the house using 90 degree connectors and then box it in, which i don't really want to do, or can i drill a new hole and feed the waste out to the left hand side of the stack, which doesn't leave much room before it encroaches on my neighbours wall.
Is there a special toilet i can buy? again ideally i would like to have a concealed cistern hidden behind a fake wall in the alcove
comments and suggestions greatly appreciated
you could turn that into a fake wall and have a concealed cistern and bring the soil pipe out on the otherside of the stack and reconnect.
measure where your stack is and measure it inside the bathroom as your stack sits to one side by the time you have built the false wall you may end up entering the stack from the rear not the sides as it is now.
will i need a special toilet with the waste pipe coming out to the side rather than straight out? is it just a matter of drilling a hole through, spinning the soil stack joint round and reconnecting? or will i need anything else? thanks for your reply
alot depends on how far out your false wall is
get your pan put a 90 degree waste connector on the rear, mark your inside wall for the centre of your stack place your toilet so your 90 and centre line of stack lines up that will give you your false wall depth.
if it's to far out then move it back to the wall and the soil pipe can come in from the side to the stack.
