Hi Guys,
Looking for a wee bit advice again please.
Tried to put Fernox F5 cleaner into system via filling loop. When I try to unscrew loop from water end(so I can attach to adapter on F5) it starts spraying out quite a bit of water?
The valve is definitely closed because when I re-tighten loop at water end and disconnect at boiler side no water comes out of it? I then try to loosen again at water end and it starts spraying out again when i'm slackening off?
Hope this makes sense.
So, I decided to put in via rad valve and that was another drama. Looks easy on pics on back of tin. Think more sprayed out than went in.
Only asking as I intend to put express inhibitor in and I'd rather do it via loop than rad.
Any ideas greatly appreciated.
Cheers.
Cheers.
