Multi-fuel stoves - are chimney liners essential
13 Apr 2006
Kent
I am looking into the possibility of having a multifuel stove fitted. It will be where the original cooking range would have been in my house.
The chimney has been blocked off for years and I know it will have to be super-swept but I was wondering if getting it lined was essential is their was enough of a draw. The opening (face on) is approx 1400mm high by 800mm wide if that has any bearing.
It's a smallish room so I will be going for a 3-4kw stove max.
Hope that all makes sense!
Hx
The correct answer is no you don't absolutely have to.
But you should have the chimney swept and checked for efficiency by a HETAS engineer. You should also inform building control.
I didn't need one, but I am fitting one as it will improve the efficiency of the stove.
You'll need to have a 'register plate' fitted - its usually a steel plate that seals off the bottom of the chimney recess. It will have a hole cut in it that fits the diameter of the flue pipe that you intend to use, and also it should have an access plate fitted, big enough to get a vacuum cleaner nozzle in to clear the soot after chimney sweeping. As said before, a flue liner is not strictly necessary so long as the chimney is in good condition with no leaks. Cheers John
