Multi PIR and outside floodlights.. tripping circuit
9 Jan 2020
I have a run of 3 floodlights with a PIR sensor at each end - a 4-core cable runs along the wall. There is also a manual override switch inside the house which energises the switched-live.
For quite a while, this would periodically trip the fus on my consumer unit - like once every week or two. But then it started tripping frequently/immediately - typically you would flip the fuse and 5s later it would trip again.
I tried to diagnose by removing one thing at at a time, then removing all of it and adding things back one at a time, but I still couldn't figure out what was wrong. I'm left with one PIR and one light, which is reliable, nothing else seems to work.
I know this is kind of open-ended but are there any specific things to look out for before I just start over? It's time-consuming that each test I have to come outside and faff up a ladded, then go inside and flip the fuse, wait, etc.
You say you disconnected them all and the circuit breaker in the C.U. still tripped. Was it an MCB or an RCD that tripped.
But now one is working. Is it the one nearest the switch that is now left working ok.
Pics of consumer unit and lights would help.
