I have a run of 3 floodlights with a PIR sensor at each end - a 4-core cable runs along the wall. There is also a manual override switch inside the house which energises the switched-live.
For quite a while, this would periodically trip the fus on my consumer unit - like once every week or two. But then it started tripping frequently/immediately - typically you would flip the fuse and 5s later it would trip again.
I tried to diagnose by removing one thing at at a time, then removing all of it and adding things back one at a time, but I still couldn't figure out what was wrong. I'm left with one PIR and one light, which is reliable, nothing else seems to work.
I know this is kind of open-ended but are there any specific things to look out for before I just start over? It's time-consuming that each test I have to come outside and faff up a ladded, then go inside and flip the fuse, wait, etc.
