Hi all,
The flat I've just moved into has 8 GU10s in the kitchen/living area. When I walked in and flicked on the switch for the very first time, the breaker tripped. On turning it back on, four of the GU10s have blown.
One I'd expect given how prone cheap GU10s are to going, but four in such close proximity is making me a bit suspicious.
I'd quite like to install the fancy smart bulbs I have bought with me, but at £25/pop I don't fancy losing four in case there's an issue with the wiring or the cans.
Am I being too fussy, or should I ask the landlord to get an electrician out to check? Alternatively I could just order four cheap GU10s and see if they die before installing my precious ones.
I've included a plot in where G is a working GU10, P is the (working) pendant B22, 4 is a (working, if dim, G4) and X is a GU10 that has blown. All GU10s and G4s are on one dedicated breaker at the consumer unit ("kitchen lights"). There is a separate switch for the G4s and the GU10s. The pendant is on a different breaker (the main lights circuit).
4 4 4
G G G G
G
P X X
X X
Cheers
4 4 4
G G G G
G
P X X
X X
Cheers
