Ah, that's better. You have successfully unconfused me, and I now understand (I hope) what you really did meanFor example, a double socket in a lounge behind a TV is unlikely to be overloaded.
APOLOGIES: OMITTED WORDS ADDED.![]()
Kind Regards, John.
... and sweet dreams to you. Tomorrow is another day!I'm off to bed. Sweet dreams!
What, 2 13A spurs on a single unfused spur off the RF?
Unbelievable.I wouldn't suggest any particular formal standard.
You hadn't said that, hence my question to you.But you think that people can discharge their legal obligations regarding the safety of that alteration without following any formal methodology - basically just say "I'm sure that'll be OK", and it will be?
Where did I say that? I merely said that there is no obligation for Mr. Homeowner to issue a BS7671 certificate.
No - what I reacted with was perfectly justified anger at the outrageous way John behaved because when he introduced a new design and asked me to comment I expressed a new concern.How {.....} dare you remark on that with a !
If you think for one second that I am arguing with you just for the sake of it you can {.....} .
And yet again you resort to insults and gutter language when anyone takes you to task on anything.
Only "probably"?You must have a short memory, since I have said several times that, out of deference to views of some here, that is what I'll probably do.
Do you still think that it might be compliant?I was wondering whether anyone could think of any way in which a pedantic Jobsworth of a PIRer (or should that be EICRer) could have a problem with it?
1) It is neither unrealistic nor unreasonable.There's never been any suggestion that such a design is either unrealistic or unreasonable, the only discussion having been about how necessary it is.
Were that a requirement then ring finals would be banned, for a start.The more general discussion (about how realistic and reasonable it is to design on the basis of the most incompetent imaginable possible actions of unknown people in the future) still stands.
If you really don't think that changing an MCB is in principle no different from changing a fuse in an FCU then it's pointless trying to discuss this with you.If you change a 40A shower load for one which is too large the cable will not be damaged. No danger will arise.
If you change a 40A shower load for one which is too large and you increase the rating of the fuse or MCB supplying it, then the cable may well be damaged and danger will arise.
If you change the 9A load for one which is too high the cable could be damaged. Danger will arise.
Only if you change the 3 x 3A fuses for higher rated ones which then allow the cable to be damaged due to excess current. If you leave the fuses as they are and try to connect 3kW loads to the FCU, then a fuse will blow.
So how are the two scenarios any different in principle?
What's the Iz of the cable?Do you consider a twin socket outlet on a non-fused spur to be reasonably safe, even though it's entirely possible for somebody to plug in a 26A load?
According to my copy of BS 7671, code 4 includes "This does not imply that the electrical installation inspected is unsafe."Maybe, but I was taking it more along the lines of a complaint that it was unsatisfactory or "needs improvement," rather than whether it doesn't comply with BS7671 but would be only a code 4.
It's hard to come up with a logical reason for choosing to contravene BS 7671.Probably a substantial majority on the first option, because there's a tendency here to recommend whatever the current version of BS7671 says rather than to actually think it through logically.
The labels - Well, personally I doubt it would be suggested at all.
I personally think that adequately labelling things (like my FCUs) should be adequate.
What does that have to do with it? I acknowledged several pages back that the arrangement does not comply with BS7671.
How would you suggest he could be sure that he had done that if he just did what he fancied ot guessed would be OK, with no observation of any recognised formal standards?Any or none in particular, so long as what he does has made reasonable provision for safety.
And the relevance of that toPrecisely. If one is supposed to allow for Mr. Other coming along, disconnecting a fixed appliance from an FCU, connecting a much more powerful appliance to the same FCU, and upgrading the fuse in that FCU from 3A to 13A, then one should, surely, also allow for Mr. or Mrs. Publics simply plugging two 3kW heaters into a double socket, which requires considerably less effort?
is what?I was wondering whether anyone could think of any way in which a pedantic Jobsworth of a PIRer (or should that be EICRer) could have a problem with it?
What's the Iz of the cable?Would it be unrealistic and unreasonable to provide protection for a non-fused spur cable feeding a twin BS1363 socket outlet?
"Mr. Spark, Did you not consider the possibility that Mr. & Mrs. Public might plug both a clothes dryer and a portable fan heater into the twin socket you fitted in their utility room?"
But I would not install such a socket.
The final upshot being the failure of about £10,000 worth of transformer.
And stupidly irresponsible.
2) Without it there is a breach of the Wiring Regulations.
3) It is therefore absolutely necessary.
You have to remember what "unsafe" means. It does not mean that something bad is guaranteed to happen".
As above.What's the Iz of the cable?Would it be unrealistic and unreasonable to provide protection for a non-fused spur cable feeding a twin BS1363 socket outlet?
As I've said, less than 26A, unless the cable is 'clipped direct' for its entire length.What's the Iz of the cable?Do you consider a twin socket outlet on a non-fused spur to be reasonably safe, even though it's entirely possible for somebody to plug in a 26A load?
That was, indeed, my initial question, and it has been well answered - there clearly are people who 'could have a problem'. Thank you, gentlemen.I was wondering whether anyone could think of any way in which a pedantic Jobsworth of a PIRer (or should that be EICRer) could have a problem with it?
The jury is out. The answer to that question depends entirely upon the extent to which a designer is allowed to determine/specify the 'design current' of a circuit supplying a fixed load.Do you still think that it might be compliant?
It wasn't a 'new concern' which arose of out of any 'new design'. The single feed from the ring had been there all along, so you had had ample previous opportunities to express any concerns you may have had about the point loading of the ring. However, you didn't express any such concerns, the only concern you expressed relating to the CCC of the cable. When I suggested removing that concern for you, by increasing cable CSA (but changing nothing else) you obviously couldn't continue to use your previous argument, so raised the 'new concern' which you hadn't previously mentioned.No - what I reacted with was perfectly justified anger at the outrageous way John behaved because when he introduced a new design and asked me to comment I expressed a new concern.
Perhaps the answer is for the fuse holders in FCUs to be re-designed such that the rating of the fuse is determined by the holder. This would require that there was also a range of matching fuses where the mechanical size was related to the fuse's rating making it impossible to fit a 13 amp fuse into an FCU protecting a 3 amp circuit.
That won't of course prevent the determined, un-informed and thoughtless person changing the FCU at a later date.
