In my garage there was originally one double socket on an RCD. The previous owner of the house has T'd in to this to add a single socket elsewhere in the garage. The T was done in a very haphazard way which I need to soft out anyway, however, a friend recently pointed out to me that it really should be a ring in the garage if there is more than one socket. In the longer term I'm planning to build a work area in one corner, so will be adding more sockets.
Should I be looking to re-wire the garage as a ring? If so, will the existing RCD continue to be okay, or do I need to replace that on the CU as well?
Thanks.
Thanks.
