Someone has clad the underside of the rafters with OSB (John - if you are thinking about sarking boards, they are generally often plywood, but are fitted on top of the rafters and carry the membrane, so you'd stilll see the rafters). No way to know what is above that OSB without either taking id down or drilling a hole in it with a hole saw. The extra strutting in the ceiling joists, together with their dimensions points to it having probably been built with provision for conversion - and then the sparky got in there, the cabbage!
