Looked good, was fun watching those nice clean clothes get grubbier and grubbier.
Did they teach you to stat at the bottom and work up?
I have not met a right handed spread that does not start from the left.
Me included.
Always start at the top and work down.
If it's too thin a layer then you need to add less water. It's the viscosity of the mix that decides your thickness. Use a bigger trowel (or darby) if you want to get flatness and use your finishing trowel to polish (but not too much).
iturner15";p="2915136 said:If it's too thin a layer then you need to add less water. It's the viscosity of the mix that decides your thickness. Use a bigger trowel (or darby) if you want to get flatness and use your finishing trowel to polish (but not too much).
I actually thought I mixed up quite dry! Maybe I just wasn't putting enough on the trowel....
I never thought or was taught to use a darby, sounds like a great idea, what stage would you do that at?[/q
Did you put 2 coats of skim on it?
