I said I was using WAGO's for the first time on job and would let you all know the outcome.
I have used them mainly for lighting circuits.
The time saving is indisputable I managed to connect and hang a brass alloy chandelier in under 2 minutes
, no juggling with a connector block and terminal driver, fantastic
. All contained inside a 'WAGOBOX' so very neat and secure
Now they claim that the WAGO will work with 'flex' down to 0.75mm
, this part is where I think the choc block connector has its advantage.
On one occasion it took 10 attempts
to get a satisfactory 'grip' of the flex and this was only achieved when doubled with a solid core.
I made a point of giving plenty of freshly stripped flex so that it could be twisted and doubled but on some occasions this still proved difficult.
They are a great help for flouresent lights and they give a very neat appearance, maintenance or exchange of a fitting will also be greatly eased.
However it has still meant creating inspection 'traps'
for them in the floor void, even thou they can very easily be accessed via the cable entry point.
Overall I really do quite like them, however, at about 11pence each there is a cost implication.
I intend to try out the 'push' connectors next and will do on the next job.
Worth considering I feel.
Any body else worked with them yet?
