    Dismiss Notice
Myson Apollo differential temperature
Discussion in 'Plumbing and Central Heating' started by wilroda, 2 Jan 2007.
  1. wilroda
    wilroda
    4 Feb 2006
    42
    Thanks Received:
    Bournemouth
    Country:
    I have a Myson Apollo 80B boiler.
    I measured the input and output temperatures with a type K thermocouple mounted on the copper pipes as close to the boiler as possible.
    The inlet temperature measures 52 deg C and the outlet temperature measures 57 deg C . Therefore a 5 deg temperature difference.
    I believe that on a new boiler this difference should be 11 deg C.
    Bearing in mind that i believe the boiler to be approx 10 years old is this acceptable or inefficient?
  2. DP
    DP
    10 Dec 2003
    14,848
    Thanks Received:
    3,261
    Glasgow
    Country:
    Are you measuring at the boiler or a remote radiator?
  3. Sponsored Links
  4. wilroda
    wilroda
    4 Feb 2006
    42
    Thanks Received:
    Bournemouth
    Country:
    Hi
    I have measured it at the boiler.
  5. Slugbabydotcom
    Slugbabydotcom
    10 Mar 2005
    3,512
    Thanks Received:
    86
    Middlesbrough
    Country:
    So long as it is no more than 11ÂșC its ok.
    It may mean that there is room to close your by-pass slightly to get more efficacy from your pump
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
