D
Deleted member 267285
Update: changed the 2 heads over, made no difference. Changed the cylinder stat for a new Honeywell. Need to check the temp. Boiler still fires up, then off, then about 2 mins later fires up again, and possibly another cycle after that (not sure if this has any bearing on situation).
Edited: I’m thinking the cycling maybe to do with the gas valve, as it makes a loud clunk when boiler fires and when finished. Is there a way to test this, or just replace?
