Myson iVector vs Hi Line fan convectors for Conservatory
7 Sep 2011
London
Anyone have any experience with the new Myson iVector fan convectors?
iVector info
I'm looking to replace two old rads in my conservatory and am considering either the Myson iVector IV60x140 or the Myson Hi Line RC 20-14.
I have done the full heat loss calcs (using proper software) and the conservatory needs just under 4400W / 15000 BTU, so either of those models should do ok.
The iVector is the newest version (just came out in October) and sounds great, but I'm always a bit leary about being the first one to try a new product - especially when it's around £500.
My understanding is that the Hi-Line should ideally be on a separate circuit. I am wondering if that also applies to the iVectors or not as the site says each one is individually programmable and has a night set back temp - so it sounds more like it has a programmable TRV and may not need to be on a separate circuit like a regular fan convector.
That would be good as the conservatory is not currently on a separate circuit at the moment and I'm not sure how easy it would be change it over.
Any advice appreciated.
System Info: (All Vaillant)
Vaillant ecoTEC 624 plus system boiler - 3-4 years old, just serviced
All the below are new:
Vaillant uniSTOR 260 unvented cylinder
VR65 control centre
VR10 NTC
VRT 392f wireless programmable room control
16 new Stelrad radiators
Rads are all slighly oversized for the rooms. Total KW for rads 19.878KW + ~3KW for DHW = 22.878KW
- does not include conservatory rads
Return temp at the boiler is currently 54 degrees. Rads all heat up ok, but the system is probably not optimally balanced - I'll be addressing that soon.
The pipework to the conservatory is 15mm.
Thanks!
Tim
