Myson Kickspace doesn't switch on automatically
3 Apr 2016
I have 3 Myson Kickspace heaters in my kitchen (previous owner installed in 2012). The instructions say the fan should come on with the heating system, however it doesn't. I have to switch the fan to position '1' manually. This same problem happens on all 3 units. Summer/winter setting makes no difference. The rest of the heating system seems to be fine and the heaters are blowing hot air when switched.
you leave them switched on all the time then once the unit senses that the water running through it has reached 32 degrees C then the fan will come on automatically same when the boiler goes off and water falls below that temperature then the fans on the kick spaces will switch off
