    Dismiss Notice
Need a new manhole cover but where from?
Discussion in 'General DIY' started by magsy01, 23 Feb 2011.
  1. magsy01
    magsy01
    9 Oct 2008
    19
    Thanks Received:
    Essex
    Country:
    Hi
    Have got a broken drain cover on my property, its the main drain access for neighbours drains too. Its a rectangle shape its holding together but its in 2 pieces.
    Been told that you cant buy just the cover anymore and will have to dig out the frame to renew the whole thing at roughly £350.
    I was hoping to just buy a new cover and pop it on, can I just buy a cover or should I look into replacing the whole thing?
    Thankyou for your advice.
    Mag
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    21,087
    Thanks Received:
    4,080
    Northumberland
    Country:
    I guess this is the two triangle one?
    Long established builders merchants should be able to get them - not cheap though at around £150 (last year).
    Do measure it accurately before you go hunting!
    John :)
    • Thanks Thanks x 1
  4. OwainDIYer
    OwainDIYer
    5 May 2010
    4,494
    Thanks Received:
    685
    Stirlingshire
    Country:
    Normally you need to replace the cover and the frame, because different manufacturers aren't interchangeable.
    The frame will only be buried a few inches though and should come out with an afternoon's work with a pickaxe
    • Thanks Thanks x 1
  5. cumbriahandyman
    cumbriahandyman
    23 Nov 2010
    1,256
    Thanks Received:
    43
    Country:
    • Thanks Thanks x 1
  6. misterhelpful
    misterhelpful
    19 Feb 2011
    3,206
    Thanks Received:
    523
    Ohio (formerly Mid Glamorgan)
    Country:
    If you are talking about a standard manhole cover (rectangular, silver with 2 handles/holes) then they are available from B&Q and wickes, at around £20 with the frame.
    Mine was rusted and flimsy and needed replacing so I looked at them last summer. I measured the existing cover and purchased one that had the exact same measurements on the label, hoping that the lid would fit the existing frame. However, much to my annoyance, when I got home I found that the new one was exactly the same width as the original but some 30mm longer. (You may be luckier!)
    In the end, I had to replace the frame and cover which did mean digging out the surrounding slabs, cutting them to fit and re-bedding them around the new one.
    Assuming this is the type you are looking for, then I would suggest £350 seems rather steep for a job that took me, alone, only about 4 hours. Of course, any remedial work concerning your replacement may differ greatly thus increasing labour and material costs.
    • Thanks Thanks x 1
  7. magsy01
    magsy01
    9 Oct 2008
    19
    Thanks Received:
    Essex
    Country:
    thanks everyone for your helpful info.
    "2 triangle" not sure about that.
    Will have a look at it tomorrow.
    There is a builders merchants we can look at, will do that at weekend.
    Cheers.
  8. Sponsored Links
  9. merlin50
    merlin50
    10 Jul 2010
    1,749
    Thanks Received:
    127
    Cornwall
    Country:
    • Thanks Thanks x 1
  10. geraint
    geraint
    28 Aug 2008
    1,710
    Thanks Received:
    24
    Hampshire
    Country:
    from a manhole cover shop..... :D
  11. Nige F
    Nige F
    28 Jun 2005
    20,422
    Thanks Received:
    1,570
    Country:
    From the local tip/recycling centre :idea: they quite often keep the covers/rims
    • Thanks Thanks x 1
  12. nickdsjnk
    nickdsjnk
    6 Jan 2010
    55
    Thanks Received:
    5
    London
    Country:
    what's it made of? if it's cast iron you might be able to get it welded locally. It's a specialist job but certainly possible.
    • Thanks Thanks x 1
  13. magsy01
    magsy01
    9 Oct 2008
    19
    Thanks Received:
    Essex
    Country:
    In case anybody was wondering, a little while after I made these posts, the sewage company took over responsibility of all manholes and drains on peoples property, so I just waited for a bit and they replaced the cover...with no cost to us..yay!
    :D
    Thanks for all your helpful replies.
    Mag
    • Thanks Thanks x 1
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
