Need a New Thermostat: Worth Getting a Hive?
7 Jan 2014
West Glamorgan
My Honeywell CM927 'move-around-the-house' thermostat's display is making it hard to program, and the clock part is the worst bit. BG will do a replacement of their choice for my £60 excess; or put in Hive for £179. Is it worth going for? I believe the Honeywell is about £100 to buy, not fitted.
CG
not all worcester combis can use the hive you will have to be more specific there are lots of worcester combis
Fair point Ianmcd, but my OP does make clear that BG would be happy to fit one for £179. Kinda suggests that my Greenstar 37 is ok.
If it's any help, and assuming you have a maintenance contract with BG - we called them out for a genuine fault. The engineer said he could fit Hive for £50 less while he was there.
Thanks for that. I wondered why the service guy insisted on leaving his mobile number- commission? I'll give him a ring.
I would like to second what Alan said. Was offered it by BG for £149 fitted, this was during the yearly service.
Bg guys have a 30% sales target so they will jump through any hoops you put up to sell you something.
Go to your local plumbcenter and ask for a Centerbrand programmable stat.
It's almost identical to the one you have, as it's made by Honeywell.
It'll take you less than a minute to change, as the receivers are the same.
I think they're £60 inc vat
I fitted a hive for a customer a few months back and to be honest I wasn't that impressed with it. Like kidgreen61 says you could replace it for something similar and it would be cheaper but if you're determined to get a smart stat installed then I would suggest a nest, Ive found that they're much better than the hive
you may have a creditable answer but why move it around the house.room thermostats over the years have been known to offer decent comfort levels & fuel savings when permanently wall fixed in a suitable position reacting to an adjacent suitable radiator without a trv on a properly installed system.
:mrgreen:
