Need a plan for electric UFH
2 Jun 2010
London
Will be ripping hardwood floor out (around 20 square metres) and installing tiles with electric UFH with thermostat/app control
What is the best setup/what do i need to make it max efficient ?
Well, tiles of course.
Then UFH undeneath (any recommendations )?
What needs to go between concrete and UFH system ?
Thx
All resistive electric heating is 100% efficient at the point of use. It's also the most expensive form of heating you can get.
A substantial amount of insulation, otherwise all of the energy you put in will be used to heat the concrete and whatever is below it.
Ill use it just to heat the tiles, got radiator to heat the room.
You don't need UFH.
What is "very expensive" ?
Even at a very low 100W/m² which would barely be enough to do anything, that's 2kW of connected load, 50p/hour to operate, and if used for only 6 hours a day which would just about be enough time to notice any heating effect, that's already £1000 per year and every year from now until it breaks just to slightly warm a few tiles in one room.
You don't need UFH.
It does sound expensive, although that amount assumes usage of 365/year. Defo woud not use it in summer, but still would cost a bit.
Often overlooked , you can’t usually put any floor coverings (rugs etc) or furniture over he heated area .
Personally, I'd rip out ceramic/stone tiles and fit something warmer underfoot like a nice hardwood floor.
Any of the Tile places will help you design a ruinously expensive to run electric mat heating system.
Look at overlay wet UFH as well?
Have hardwood floor at the moment and because it was not installed correctly, it started to warp. To the point that it started to lift in one spot, same way as if two sheets of ice pushing against each other. Scared to install wood again and risk same thing happening ...
Im really lost and confused, dont know which direction to go.
