I have had a roofer to check for this problem and he think it's a big job (£500+ ). I just dont get it. !! why ?
I checked in loft, and absolutely no sign of leak anywhere.. I had someone else to check if any broken tiles and none.
If i go back, the problem started about a year ago when one roofer inserted a led plate or something.. as he mentioned to stop water dripping on my door from between the wall and gutter. i believe there was a gap..
My windows for that room and other bedrooms are open 24 x7 so air flow is not an issue.
What i think has happened, although i have little roofing knowledge is, he might have pushed the felt(or whatever its called, the plastic) while pushing the led tray in, creating an uncovered area above the wall. The water is only appearing on the wall inside, creating a wet wall if you put your handover and in some areas the colors is coming off..
I have another roofer coming in next week to see, but just thought get some more info and opinion so i can ask him questions..
Please let me know if there is a cheaper roofer in bolton area. thanks
View media item 65769 View media item 65770
