- Joined
- 3 Jun 2016
- Messages
- 4
- Reaction score
- 0
- Country
My house is a two-storey building with an integral but separate garage underneath. Currently the main access/exit to the house is via the front-door which is on the first floor level, accessed via an external set of stairs from the ground floor. The garage is accessed from the ground floor and currently there is no internal access from the garage to the house (and vice versa).
My plan is to convert the garage to a kitchen, by replacing the garage door with an additional front door (the garage opens onto the garden at the rear) and building an internal staircase from the new kitchen through to the first floor. This new staircase would open directly to the lounge on the first floor. The lounge has a door which opens onto the hallway (which has access to the current front door and up to the top floor, with bedrooms and bathroom). No rooms are accessed via the lounge and no rooms would be accessed from the new kitchen.
My question is, would the new internal staircase need to be enclosed with a fire door either at the top (opening onto the lounge) or at the bottom (closing the access from the kitchen up to the lounge). Or even both?
The escape routes for the upper two storeys will remain unchanged from the current arrangements; ie in the event of a fire you would exit the first floor via the front door or via an accessible window to the rear.
In the new kitchen, the escape routes will also be the same - or even enhanced. So you will exit via the new ground floor "front door" (which unlike the existing garage door would be easier to open from the inside) or via a door into the garden at the rear. The only difference will be that currently there is no "opening" directly from the ground floor to the first floor because the garage though covering the entire ground floor of the property is entirely self contained. So on that basis, a fire in the new kitchen could spread to the first floor via the staircase?
Three builders quoting for the work have told me three different things; no fire door required, one fire door required (at either the top or the bottom of the new internal staircase) and finally that the entire new staircase would need to be fully enclosed.
I made preliminary enquiries with my local building control, on the general concept of converting the garage (as there are some local restrictions on permitted development if the proposals impact on car parking space) and they confirmed that nothing other than building regulation approvals would be required. But obviously this didn't go into the details of fire refs etc.
