need help from spark?
15 Jul 2014
London
im doing my house up and have an emergency outside light which I have put on a separate pir before I step out I have a three core going to my light which is from the pir and a feed in to the light and a feed out to the other light my em light has sl permant neutral and earth of coure but im unsure of which brown is going in what I want my black as the permenant because that's what it is in my other em light
Emergency light or security light?
Do you have details on this product?
Pictures of the existing wiring would be helpful and do you have any means of testing for voltage, such as a two pole voltage indicator?
There are three types of emergency light.
Non maintained turns on with power failure so just line, neutral and earth if required.
The maintained is split into two some similar to non maintained but are on all the time not just with power cut so again just line, neutral and earth if required. And then there are the type with two line connections one permanent and one switched the latter should go to the PIR.
I have in the past ordered the wrong type of maintained emergency light which just stays on all the time.
emergency light it has the terminals for sl permenant and neutral
I have my feed in and my feed out and my three core from the pir
I want it to turn on when pir sensor is triggered
also want it to be on in emergency of course
so where does my wires go ? please
They go where the wiring diagrams for the light and the PIR detector indicate they go.
