Hi
moved into Partner's old 1950's flat recently and trying to make sense of the telephony setup. Broadband is slow (10Mb when should be 30Mb) and wiring hasn't been touched for a long time.
Long term IT specialist - but used to ethernet - not this stuff. Any help appreciated - see images
* Junction box at front door - wiring comes through from outside - Has what looks like on top white and orange (or brown - I'm not touching the wiring at the moment given the state) connecting to white/blue and blue/white below respectively.
* socket near front door - has been played with (not by me!) white/blue and blue are connected as is blue/white to orange . There is no connection to the actual external socket. I'd assumed this was the main box - until I saw there was a capacitor in the living room box!
* socket in living room - orange and blue to points 2 and 5 respectively. And a capacitor so assuming this is the main box (not the extension)
So if I'm reading this right it's
Junction is incoming presenting white-> white/blue and orange-> blue/white
This then gets connected at the socket near door white/blue -> blue and blue/white -> orange
The blue and orange then run to the living room and are presented as a "main box
... ie: there's multiple connections between the function before it gets to the main box
and if I wanted to make it "right" with mainbox near the door and extension in the living room I would do following:
1. in socked near front door which I want to be master connect white/blue to 5 and blue/white to 2 on a new master box
2. use the orange and blue which were previously connected in the box for the extension at both ends
help appreciated!
help appreciated!
