I have a pump, and a shower mixer which I believe the pipe from pump to shower should keep it as 22mm.
However the shower mixer Cold & Hot inlet is 1/2" (the inlet of the s-union with the chrome plates, then connect to 3/4" to the mixer)
I need an elbow joint to connect from the 22mm (rising from the floor) to the 1/2" male. Which type of elbow should I use? (any example from screwfix?)
Should I reduce the 22 to 15mm first when it comes vertical from the floor?
many many thanks!
many many thanks!
