Hi
I am trying to find a nice slim radiator to go behind a door -
I found these 2 options but am a bit confused by the dimensions.
I interpreted 'Depth' being the total depth of the radiator including the bracket..ie this would be the total 'clearance' I need to allow?
But if that is correct interpretation then I don't understand why the 'Wall to Centre' measurements given are greater - in the first one for example how can the minimum total depth of the radiator including brackets be 26mm ... but yet the minimum wall to centre is 40mm? Surely the wall to centre measurement should be smaller?
Grateful for advice/explanation to help me understand!!
http://www.screwfix.com/p/barlo-rou...iator-h-600-x-w-800mm/22432?_requestid=118047
DIMENSIONS:
H x W: 600 x 800mm. Depth (min. to max.): 26-36mm (depending on use of brackets). Wall to centre (min. to max.): 40-50mm (depending on use of brackets)
http://www.screwfix.com/p/kudox-pre...single-convector-radiator-white-600x800/26289
DIMENSIONS:
Depth (min. to max.): 50-65mm (depending on use of brackets). Wall to centre (min. to max.): 54.5-69.5mm (depending on use of brackets).
DIMENSIONS:
DIMENSIONS:
