Hi. My first post here.
In the faqs section, there are great instructions on repressurising an expansion vessel but I'm not sure about one point. One part says:
"Drain enough water from the system to top drop the water pressure as read on the boiler gauge, to Zero. Close the drain cock. "
Then later it says:
"When you get to 10psi, undo your drain cock again. If there was still water in the PV, your air pressure will force it out. If that happens, recheck the pressure and pump more, and repeat until undoing the drain cock doesn't give you a spurt of water. "
The thing is, surely water is just going to come out of the drain cock at this point, as you wouldn't have fully drained the system. So is it that you should just get a steady flow of water, as opposed to a spurt? And anyway, wouldn't you expert a sort of spurt, because you've effectively increased the pressure on the system side by pressurising the air side of the diaphragm 15 psi?
Thanks.
Then later it says:
Thanks.
