Hey all,
Spark fitted under cupboard lighting using T5 fluorescents. The first issue I have is that they came with "Cool White" bulbs which look awful but the second issue, and more annoying, is that he fitted a single 883mm tube running at 21w and beside it 2x225mm running at 6w and therefore are a lot duller.
This will give you a better idea of what I mean:
The two 225mm obviously run under the corners but they are noticeably duller:
Now firstly I will be changing bulbs to Warm White but I need help addressing the 2 smaller bulbs as I imagine that even with the warm white's that corner is still gonna be duller.
Do I change the 3 units to 2 and have them of equal length or is there another way to sort this out?
Any help at all guys would be appreciated. Thanks
