hi, I'm just about to embark on adding a new zone to my central heating system. At the moment I am servicing my flat with my boiler and a honeywell wireless thermostat.
I'm just finishing off a new flat in the front of my building which will be used less than the main flat.
What I'd like to do now is add that new flat to the central heating system, but I want it to be able to independently control its own heating. So I want two thermostats, one for each flat. Plus I understand I will need some mechanical valves. There is a small problem that is one of the rads on the main home is on the way to the new flat (I'll try and up load a drawing if requested). This basically means I don't have a natural tee point, unless I re-plumb this outrigger rad.
I saw this kit http://www.screwfix.com/p/honeywell-smartfit-7-day-s-plan-heating-pack/81398 which has two actuators, so maybe this will work for what I need? only problem I can see it only has one thermostat.
Can anyone suggest I product or set of products that I could get to achieve this, I'm sure its pretty standard practice.
Image:
Image:
