Need window keys
25 Apr 2005
Just moved into a new house, it had doubled glazed with wood frame windows. I dont have any keys, can these be bought from diy stores etc.
Its a Barrat home about 10 years old if that helps
What sort of lock is it?
Can you show a picture from the website?
ill try and get a pic now from a site.
The actual lock is on the arm that you use to open the window then support it in a position. Once the wondow is closed you put the arm down horizontally. The Arm has a small round lock on it, so i presume a small sized key is required.
I'm guessing this maybe the key you need, yes you can buy the key only. A locksmith shop might be your best option.
