Ok,
This is related to a previous post.
It appears that i have a blockage in the primary coil of my unvented cylinder. I know this as I have taken off the inlet and outlet pipes of the coil. The feed pipe is clear and the return is to.
I cant blow through the coil - or suck - used a wet vac to do so.
In my stupidity - I pushed some think plastic "wire" into the coil thinking I could dislodge the blockage or prove the coil was free as the "wire" would exit the other end of the coil. The "wire" btw is that used in industrial strimmers.
Anyway you've guessed it, the wire is now firmly stuck in the coil and will not pull out.
Any helpful ideas?
C
Any helpful ideas?
C
