HI, water not heating, local engineer says no feed from PCB, He can replace but thinks it will need reprogramming which means a Bosch AGent, is this likely?, the cost of this will write off the machine, I'm thinking of removing relays to test , are they availiable? will reprogramming still be needed?. THe machine is hardly used, heater tests ok,20 ohms.PCB looks clean no bad joints.
