- Joined
- 7 Sep 2022
- Messages
- 4,919
- Reaction score
- 1,427
- Country
Still waiting on response to how thick the floor is (how deep the joists are) and that floor plan btw. Perhaps one of your neighbours with an identical house has theirs up on rightmove..
You showed a picture of upstairs with floorboards lifted; you can measure the joist depth there. Floorplan would be what, less than 10 rectangles on a piece of paper for the downstairs and upstairs, photoed and uploaded, with an indication which direction joists run; not after a millimetre perfect scale drawing, just trying to find out where the room is in relation to the rest of everything around it including neighboursI tried to push open the ceiling panels but they are totally unmovable.
I'm sorry Harry but if an electrician did not have the intelligence to sort this problem then I would not have much confidence in his electrical skills. It probably won't be cheap and would involve an unusual amount of work WRT installing an extractor, but heaven help us if things have sunk that low that they aren't prepared to put themselves out for a customer.Why are you talking to electricians to install this for you? An electrician usually deals with the wiring, rather than the installation you need - what you need it a builder, or perhaps a general handyman.
I've never seen it that way myself.An electricians job, usually ends at the ends of the wiring, and the wiring accessories, they are no builders, plumbers, or joiners. So why expect one to have the tools and expertise to cut through walls and install ducts? The electrical part of the job, is a tiny proportion of the job. Intelligence of the electrician, is nothing to do with it at all, rather it is a matter of calling in the correct trade for the major part of the job.
Yes and as an electrician I've never baulked at cutting holes through walls to fit extractors in kitchens or bathrooms. Plus I did build my own bungalow after demolishing an old chappel by hand and clearing the site.I did employ other trades where necasary,like making doors and windows and installing gas appliances and doing the plastering, but little else. I seem to recall from some of your posts that you don't have any qualms about tackling jobs you have never done before.Are you a qualified, professional tradesman? Horses for courses. You never engage a plumber to build a house, nor a builder, to rewire the place.
"Hi I'm sorry but I think that will be to difficult to do it." Was the response exactly from one and pretty much the same response from the others in different words. They are just not interested in difficult jobs.I'm sorry Harry but if an electrician did not have the intelligence to sort this problem then I would not have much confidence in his electrical skills. It probably won't be cheap and would involve an unusual amount of work WRT installing an extractor, but heaven help us if things have sunk that low that they aren't prepared to put themselves out for a customer.
