Neon Light Switch
20 Apr 2014
I'm trying to replace an ordinary one way one gang light switch with a neon indicator switch. I have only one red ( live) and one black (switch live) to connect, however I have 4 option L supply, N supply, L load, N load. I need to find out if I can use the switch. How can I wire it in such a way that when it is switch on, the neon illuminates and vice versa.
Andy
what the previous post was trying to say is, what you want will not work as it is, your neon requires a neutral to operate
The switch and back box is plastic, could I feed the neutral through the spare earth wire ??
Hi - may I ask why you need the neon? Is it (eg) so you can find the switch in the dark?
Kind Regards
________
CJG, U.K
