HI I have a glow worm betacom 30c. I have no house thermostat im fed up with going in and out to the cold garage to turn heating on and off. had it serviced 3 weeks ago and my gas man wanted £145 to supply and fit a standard thermostat.
Looking a buying a nest my parents have npower and they could get me one for £129 at the moment, I belive I should install going off the dry circuit diagram, Live and neutral to heat link seems stright forward enough.
My boiler has 2 different thermostat blocks inside, the 240v one, and the low voltage 24v one, am I right in thinking I just use the low voltage block remove the link and wire to heatlink 2 & 3 & that's it? I will be using the display in the front im not wiring it through the house, just on mains plug.
Please could someone confirm is it that simple. or am I missing something ?
Cheers Ted.
Cheers Ted.
