I'm looking to install some network cabling around the house - I have quite a lot of network equipment dotted around and my wireless isn't particularly great and I've had some issues with Powerline adaptors as well. I installed network points all around my last house but I haven't had the time to do it since I moved last year.
My main requirement is a bunch of network feeds to my TV for various equipment, a couple to my home office, and a couple into the loft where the NVR for my CCTV lives. I also intend to install an access point, probably a Ubiquiti on the upstairs landing to provide improved wireless to the bedrooms where I doubt I'll install any network points.
My questions:
1) Is there any need to consider CAT6 over CAT5E? My thoughts for home use are CAT5E should be more than sufficient?
2) Is there much different between brands of cable? I'll buy solid copper rather than CCA or CCS but beyond that is there much difference?
3) Is there any difference with external grade cable other than additional UV protection? Is it any different or harder to work with? In essence, if I end up having to run any of the cables externally, is there any harm in just buying external grade and using it for everything?
4) At my main TV, as an example, I need a minimum of 4 network connections. Would I be better installing 4 cables (or probably 6 to provide some scope for future growth) or just install a single cable and add a cheap switch under the TV? I can see pro's and con's of each approach.
5) I'm undecided whether I'm going to run all the cabling back to where my router is currently, or into one of the loft spaces, with a single cable running back from there to the router. Is there any downside to the latter approach? If I ran it all back to the router I'm going to need to add an additional 8 or 16 port switch anyway so keeping it all in the loft for neatness seems the most logical idea to me?
6) I know to keep network and coax cables away from mains cables where I can. Is there any harm running CAT5E and coax (for TV and/or satellite) together?
Anything else I need to consider?
My questions:
