I have just purchased a new house and after using my rapitest 13amp socket tester, half the sockets up stairs seam to have a neutral fault. what should I do?
Good advice! i'd only add to it by saying that until the electrician comes round to fix it i'd not use the offending sockets and if possible pull the fuse/breaker to the circuit.
